Done: Three Handsaw Refurbs
Blog entry by Smitty_Cabinetshop posted 100 days ago 1024 reads 1 time favorited 69 comments Add to Favorites Watch
There are so many outstanding saw restorations on LumberJocks, I hesitate to post my first attempt. But I have a cheap saw that has the potential to be a good user, so here goes.
=========== Edit #3 ===============
Now a third saw, a D-8 thumbhole variety….
See blog entries in posts below.
========== Edit #2 =================
Okay, here’s another saw for my own type of refurb. First I drilled a ‘new’ blade to match up with a keeper handle:
Now I’ll clean up / polish the nuts, strip and sand the handle, clean and oil the blade, then soak the handle in tinted BLO before pulling the parts together. Update / completion will be posted below. ==================================
The tote drew me to the saw in the first place, which was at an outdoor flea mkt area in a neighboring town. I went back a week after seeing it initially and paid the $1 asking price. Here are the as-purchased pics:
Took it apart, and the blade went into a makeshift Evaporust tank for a day or two.
Now for the tote. It’s fancy in it’s carving, and obviously well worn. Someone loved the saw, and it’s clearly an everyday user from someone’s past. Problem is a missing upper horn. I used a 1” chisel to flatten the chipped surface, and even after an initial effort there’s evidence the horn’s base was sanded over OR worn smooth by hand over the years… So the piece I add will be shaped with rasp, saw and file to something, but first and foremost needs complete contact at the glue surfaces.
The saw on the left is the donor, and a cut of it’s horn was made:
More chisel work, some sanding, paring, etc. and I have an oversized donor piece glued in place to set until I try shaping it.
More to come!
-- Don't anthropomorphize your handplanes. They hate it when you do that. -- Old Tools Archive
69 comments so far
View lysdexic's profile (online now)
lysdexic
1145 posts in 428 days
#1 posted 100 days ago
Looks quite encouraging. Can you tell grain direction and the relationship between donor and recipient?
Two days in ER that is quite a while. I am interested to see how the pitting turns out.
-- Scott
Smitty_Cabinetshop
2922 posts in 423 days
#2 posted 100 days ago
Truth? Don’t know about the grain at all. It was placement of the donor that was number one at this point… If it doesn’t hold as I’m working it, I’ll sand the original and what’s left of the donor and start iteration number two, with grain as #1… Brit told me align the grain; I’m hoping I get lucky. :-)
View superdav721's profile
superdav721
4694 posts in 645 days
#3 posted 100 days ago
Looking good Smitty. Keep us tuned in. Do you or would you want to put a dowel in your horn repair?
-- No matter where you go - there you are ~dave~
Smitty_Cabinetshop
#4 posted 100 days ago
Thanks Dave. It’s pretty ugly right now, but I think I have enough material in the added piece to (obviously) removed the battered edge and leave a nice, clean demarc. RE: the dowel, there’s not one there in what was glued tonight. I’m putting my stock in a solid joint, one that’s strong enough to withstand the shaping I’ll be doing. If it fails, I’ll look at other options.
View Brandon W's profile
Brandon W
2184 posts in 756 days
#5 posted 100 days ago
Great idea, Smitty, stealing a horn from another handle. Also, the other handle should be a good source of other small scraps for future restores. Looking forward to seeing how this thing turns out!
-- Brandon W -- als ik kan
Smitty_Cabinetshop
#6 posted 100 days ago
Okay, couldn’t stand it. After letting the transplanted horn set for about 3 1/2 hours, I went out to see what it looked like and to start filing. Very pedestrian tools: a small rasp, some bandsaw work on the outside edge, a 3M 180 grit foam sanding block, and some 100 grit sandpaper wrapped around a dowel rod. Here’s where it is as of tonight.
So far, so good! It’s an art more than a science, figuring out where soft curves turn into hard edges. On a time-worn handle like this one, though, the pressure is pretty much off… :-)
lysdexic
#7 posted 100 days ago
That looks really good
-- Scott
superdav721
#8 posted 100 days ago
Starting to look a lot better.
View Don W's profile
Don W
4388 posts in 373 days
#9 posted 100 days ago
Smitty, I think that will work.
-- dw - Build with your hands, with your mind, and with your heart. (http://timetestedtools.wordpress.com)
Smitty_Cabinetshop
#10 posted 99 days ago
Wondering about getting the handle ready for finish. Is fine sandpaper pretty much the 90% solution? Don’t want to erode the carvings anymore than I have to, but stripper seems harsh.
lysdexic
#11 posted 99 days ago
On my D-8 I used a cabinet scraper to remove the finish, sanded to a 320, then wet sanded varnish with 400 grit w/d paper.
Over the carving a sanding block would be helpful.
-- Scott
Smitty_Cabinetshop
#12 posted 99 days ago
I like that. Many nooks and crannies in this tote, so I thinking my mini-files will get a bit of a work out, too. Thanks.
View Dallas's profile
Dallas
699 posts in 292 days
#13 posted 99 days ago
Smitty, I just have to say it looks as if you are in fine fettle today!
Smitty_Cabinetshop
#14 posted 99 days ago
Thanks, Dallas!
Here’s an update, after just a bit of sanding and shaping again this evening. I’m liking the graft…
The whole thing with the light sanding everywhere that’s done so far. How much more sanding do I need to do?? Anyone??
superdav721
#15 posted 99 days ago
Looks good to me Smitty. What about that hair crack near the bolt hole?
showing 1 through 15 of 69 comments
